Fittings and Tubing questions
Keltron 3030
Mt. Pearl, Newfoundland
I currently have barbed fittings in my loop, however I am interested in getting some compression fittings. Are there any advantages/disadvantages to having compression fittings over barbed? I am also looking to get some new fittings for my loop when I get my new video card w/waterblock, because the card is not coming with any fittings.
I was looking at these for compression fittings: Straight Connector - 3/8 ID - 5/8 OD - Value Pack (Set of 4) Straight Connector - 3/8 ID - 5/8 OD - Value Pack (Set of 4) [3858] - $20.99 : DazMode PC Watercooling Gear, Canadian Best PC Watercooling and Modding Store
With tubing, is there any brands I should prefer/avoid?
And finally, what colour tubing do you guys think would look good in my build? I was thinking either red or white. This will help determine what size tubing/fittings I will be getting :thumb:
Thanks in advance guys!
Bungwirez
Mississauga
I am confident that barb fittings work well. the only advantage to compression fittings is that you will
1) pay more,
2) can loose whatever zip-tie you have holding the tube down - if you even use them, and
3) virtually guarentee leaklessness.
can't say I can argue with the deal on those TFC's considering single Bitspower fittings start at 9bucks.
