Folding/Gaming Rig -- need advice
Hello fellow HWC's
I am looking to build a folding rig and gaming rig, but mostly folding.
Folding/gaming - some programming
around 1800 give or take
Canada
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
not really - but remember its a folding rig
Corsair H50, G15 keyboard, G9 mouse, Dell 30" monitor, blu-ray drive
of course
absolutely
in about 2-3 weeks
9. What resolution do you use?
1920x1200
Intel i7 930
Gigabyte X58A-UD3R
Western Digital Black 1TB 64MB
Coolermaster HAF X
Silverstone Strider 750W
[FONT=Verdana, Arial, Helvetica, sans-serif]Gigabyte GeForce GTX 460 Fermi 715MHZ 1GB x2
Not sure what to get for memory. I would like it if it fits into my blue black theme but if not i can deal with it. I would like a triple channel kit.
anyway any advice would be great. Thanks
-INH
[/FONT]
