[email protected] thread. Updated as necessary - _dangtx_
_dangtx_
mtl
no reboots but temps went up...aha!! temps went up because winrar finished and prime drilling
bwm
Sounds about right, and the temps aren't really bad either.
_dangtx_
mtl
im not in hell touching core temp last time i had headaches....
the frikkin thing still hasnt rebooted lol...all voltages back down to auto except cpu and ram(stock 2.0 volts)
bwm
You may have a point there with AMD chips. It works extremely well with inhell chips though.
Good sign, unless it is supposed to and isn't :bleh:
_dangtx_
mtl
yeah but i tried 3.9ghz with voltages on auto and no boot...tried 3660mhz with 1.5v on cpu no go..backing own to 3.6 and see..it may need some nb juice
also keep in mind i dont have a cpu fan on the cooler...theres a 120mm like a couple inches away lol blowing up
bwm
Better get a 120 on the heatsink itself blowing straight through the fins.
The Antec three speed LED fans are good for that, dyke the led wires if ya hate the funky lights.
75 CFM HI, 50 something medium, works best for me. Very quiet fans overall.
bwm
wait how do you take the leds out???
Carefully trace the leads from the head of each LED back towards the hub. Cut one or the other of the two wires from each LED and bend them out of the way so they cannot short out to the other wire beside them or to the case if mounted as normal exaust fan wound be.
You can remove the LED completely but it is messy, time consuming, and still leaves the wires to contend with.
