Want to Buy FOUND: Chromecast Audio
Lysrin
Nova Scotia
Just wondering if someone might have a Chromecast Audio they'd like to sell.
Some on ebay but they are from the UK or US and seem a bit pricey.
Bond007
Nova Scotia
Good luck on the hunt. I grabbed one when bestbuy was clearing them out for $20. Very happy with the audio quality vs the bluetooth setup I was been running before (I don't notice any audio compression now).
Lysrin
Nova Scotia
Thanks. I have a Harman-Kardon unit that supports plugging an old iPod directly into it but also has a 3.5mm input. I've moved away from Apple for most of my stuff, and am trying out a Google Music family plan so thought a Chromecast Audio would support easy streaming to that unit without me having to update device music libraries.
Not sure why anyone would sell one if it is still working for them, but figured it was worth a shot! ;)
sswilson
Moncton NB
Lysrin
Nova Scotia
You'll also want to try sourcing an optical mini plug adapter to use in place of the patch cord. The CCA can output a higher quality signal that way.
edit: something like this... https://www.amazon.ca/CableCreation-Toslink-Digital-Optical-Plated/dp/B01J7MUBAK/ref=sr_1_1_sspa?crid=20BBD6BZ5TA2P&keywords=mini+toslink+to+toslink+optical+cable&qid=1560357442&s=gateway&sprefix=optical+mini,aps,171&sr=8-1-spons&psc=1
That resolved way quicker than I expected! Thanks sswilson! To think I almost didn't bother posting :biggrin:
Bond007
Nova Scotia
Nice one! Quick turn around for you. Agree with going optical if you have a free spot on your receiver. I went with this one for $9 (only 3’, so no mass of cord from it):
https://www.amazon.ca/AmazonBasics-Toslink-Mini-Digital-feet/dp/B07DTJ861V/ref=mp_s_a_1_1_sspa?keywords=mini+toslink&qid=1560369725&refinements=p_85:5690392011&rnid=5690384011&rps=1&s=gateway&sr=8-1-spons&psc=1
