Fractal Mood review by HWC
They're at Computex currently but will ask when they get back.
Any news from those guys? Googling has turned up absolutely nothing, sadly.
I really don't see any problems with the mood if I use a small air heatsink or 240mm AIO pushing its air directly Out of the case, as opposed to intaking. I doubt the 180mm top fan will starve the AIO, and there should still be plenty of airflow from it to get the GPU heat out. 🤷‍♂️ It just seems that no ones tried it, or if they have, they don't mention it in any build log I've read.
I found a company that makes a 3D printed add-on base for the Mood that gives a 140mm intake at the bottom... but they want 26$ for it 🤣. 26 USD for what? 2-3 bucks of PLA? Cmon. Hopefully once my own 3D printer is up I'll be able to laugh at these ripoff prices even more.
Meanwhile, like 50% of the bottom of the Mood is covered by a serial number sticker, Solid (un-ventilated) metal, and a janky terrible 90 degree PSU cable connection. Had they thought it through just a tiny bit more - put the PSU cable above the PCIe slots? - they could've easily added at Least an 80mm intake right above the IO panel. Would've aimed directly at the CPU and made shortish reg heatsinks a far more viable option.
