Framework Mini PC
moocow
Vancouver, BC
Framework announced AMD Strix Halo mini PC with an ITX motherboard.
EDIT: memory is soldered on
Seems the demand is so high, there is currently a 50 minute wait to even access Framework's website.
Edit: dropped to 30 minutes pretty quickly. And hasn't moved from 30 minutes for 15 minutes now.
Just going thru the press stream, they poke fun at Nvidia and Apple pricing. The more you buy, the shinier the jacket gets. Good to know that the motherboard has all ATX standard so you can put it in another case. The PSU is semi-custom Flex but not a problem if you use something else.
