fresh install advice with revo + F90 + 2TB
wess88
New member
Ok so finally I got myself to build my new pc.
here's the list of part currently inside -
i7-2600k cooled by Corsair H70
GA-z68X-UD3H-B3
Corsair XMS3 ddr3-1600 7-8-7-20 4GB x 2
Asus GTX 470
Corsair HX620
Windows 7 installed on Revo drive at the moment
also at my disposal which I can use for this computer
vertex II 120GB or Corsair F90.
I already have Sata drives which I'll clean up after I extract my useful data.
I don't really "game" but times like the summer, when my 9 yr old is on summer vacation I'll load up WoW , etc so I can keep her company when she's playing. (gotta teach her how to play SC2 still)
So my question is, should I just put everything on the revo drive (O/S, productivity apps + WoW) or
should I take advantage of the fact I can use part of that as cache for the mechanical drive (which brings the question to my mind, why bother putting it on platter drive if I"m going to cache it on SSD anyways)
now another question is, I know SSD supposedly have limited i/o cycles, what about the revo drive? anything I can do to make it "last" longer (I really dont' like reinstalling my own system) lol
Any suggestion is appreciated.
JimboToronto
>>>should I just put everything on the revo drive (O/S, productivity apps + WoW)<<<
Yes. Use your mechanical HDD for data storage only.
>>>I know SSD supposedly have limited i/o cycles, what about the revo drive? anything I can do to make it "last" longer<<<
Don't sweat it. NAND rewrite limitation hasn't been an issue for years, since SSD capacities have increased.
Even with the reduced rewrite capability of today's triple level cell 25 nanometer NAND, your SSD will be obsolete before your NAND goes read-only.
Just remember that all bets are off if you overfill any SSD. If only a small portion of the drive is available for wear leveling and idle time garbage collection, performance and longevity will suffer.
This is why all bulk data storage should be on HDDs and the SSD should be used for the OS, apps, swapfile, etc. As long as your SSD is being used at less than 50% capacity, write endurance shouldn't be an issue.
supaflyx3
Langley, BC
You shouldn't worry about the I/O on the revo drive, as long as you aren't reinstalling windows often, or stressing it out you should be fine.
