Friends Computer Crashing Randomly
AmuseMe
Saskatoon, SK
CPU: Intel Pentium E5200 (SLAY7)
Motherboard: MSI G31M3 V2 (P35 Chipstet)
RAM: OCZ 2GB DDR2 @ 400MHz
GPU: ASUS 8800GS
PSU: 460W CoolerMaster
OS: Windows XP SP3
It crashes, and blue screens for literally half a second. You can not make out what kind of error it would be (during the blue screen). Typically happens (actually, 100% of the time) when he is on one user profile, and switches to his main one.
Will crash during games, and completely freezes and locks up randomly. You don't even need to do anything to cause its lock ups.
Fresh install of Windows?
sswilson
Moncton NB
GPU: ASUS 8800GS
OS: Windows XP SP3
That would be my diagnosis. Sounds like there's a program attached to his main profile that's in conflict with something else.
He could try creating a new main profile and deleting the old one.
stoanee
Lacombe Alberta
Set the machine to hold at the blue screen so he can get a hint of what the error is. Right click on my computer> Properties > Select the 'Advanced' tab > and under 'startup and recovery' click the 'settings' button. This will open a new window, and under the 'System Failure' heading, uncheck 'Automatically restart. Then google bsod codes to try to isolate where the problem is.
AmuseMe
Saskatoon, SK
Okay, Ill try some things out. I would have just looked through similar posts' here, but I am not about to go through all of them, and try everything there is to do lol. Will be looking for issues now!
