From Q6600 to Sandy Bridge
ipaine
Edmonton, AB
So this all started with a simple step-up from a GTX 460 to a GTX 580. This of course made me want to do a full upgrade.
Before the new parts:
Here are all the new parts (no the cat was not part of the upgrade)
First picture after getting everything installed.
Definitely a much cleaner look than before.
Nice look at the 580, now I just need a second one for SLI.
Here we can see the led code, power and reset buttons. Plus there is the Asus that is lite up, the thing is I don't even remember reading about that. I'm sure I did but I don't recall. Either way it is a nice touch.
And with this you can see one of the reasons I wanted the deluxe, the front usb 3 ports. I do think it matches really well with the front of my case.
So that is it for upgrades for the time being. I know I am thinking of another 580, but food, rent, clothes for the kids, etc. just have to come first.
r0k0
Gatineau, Quebec
why are your fans from the rad pulling hot air inside the case than pushing outside ?
and good choice for the Scythe fan... very powerful fan for 35dba
enaberif
Calgahree, AB
Its how Corsair says to set the up and you'll see a slight temp difference
headsh0t
Winnipeg, MB
rock solid.
That's what your mom said. Yeah corsair says to have cool air drawing in which would work fine because it looks like he has top exhaust setup in his case so its not a big deal. I used to have it setup like that in my CM690 since it had top exhaust but I have my H50 exhausting in my current case. You're temp may drop a degree or 2 drawing air from outside the case. Only a good idea if you have top exhaust.
enaberif
Calgahree, AB
The funny thing is Corsair never really took into thought if you have a high end gpu dumping gobs of heat out the back that this thing would suck in :doh:
dma0991
That is a very nice rig you got there, great job :thumb: About the blow inwards Corsair, I would have made a duct from the fan to the fan at the top of the case. Would solve much of the hot air in the case problem.
ipaine
Edmonton, AB
Well I have made another addition to this build, the Corsair Obsidian 650D.
Figured with the 580 and the fact that I want to get another one, I better get a case that has a bit better airflow. I'm going to take my old case and either put my server stuff in it or put the spare parts from the Q6600 build into it for my kids.
I will get some pictures up once I have this all done and installed.
JmanEspresso
Member
Mahopac NY
When I was using the H70, I had originally set it up how corsair suggests, pulling air from outside the case.. However, I had better temps when I set it up as exhaust out the back.
I decided that the reason for that, was because the H70 was pulling the hot air that both my video cards were exhausting, back through the rad. So idle temps were fine, but load temps were hot.
All in all, I was quite dissapointed with the H70, but to be fair, Ive got my chip pushed as far as it can go, so maybe less of an overclock would be better suited to it.
