Gallery Fuzzy's Core P5
Father Fuzzy
B.C.
Transferred rig from a corsair 650D to the Thermaltake Core P5
Asus Maximus 4 Extreme with 3570K
Corsair AX1200 PSU
16 gig Corsair Dominators
Intel 520 ssd's
WD Black 750 gig 2.5 hard drive
AMD 6970 GPU with Koolance block
XSPC RX 480 rad
55mm trieberks fans with admiral fan shrouds
aqua computer Aqualis res with waterfall
Black Primochill acrylic tubing 3/8-1/2
ghost/revolver fittings
fun with tubing
Used a laser level to help with the measurements
ran out of black tube so used a blue piece for practice
Had to find some threaded rods to make some custom bolts to use the fan shrouds
Added a hot swap bay on the side of the case using a Caselabs 5.25 bay adapter to 3.5
Father Fuzzy
B.C.
Thanks Grinder
I did clean it eventually :whistle:
putting 2 led's in the fan shrouds looked ok but made a wiring nightmare beside the res
installed nzxt 2 metre led strip weaved into the fans
found a switch for controlling some of the lighting....Wallee
Changed over the black ghost fittings for some red anodised revolvers I picked up from HWC member Ballistix
shot of the thermaltake logo with under mobo lighting was quickly removed with some acetone
trying out some lighting on acrylic under himuru
Father Fuzzy
B.C.
tehpr0fess0r
Calgary, AB
Damn, those black tubes look sweet! Makes me want to build another PC just so I can use some of those.
Is the waterfall effect audible? It would drive me nuts to hear water dripping all the time
