G4 mac was given to me
Shadowmeph
I just use Tonymacx86 as reference for all my built. If you follow the build guide, you pretty much have a 90% solid build.
tonymacx86.com
I built one two years ago and it was buggy really buggy. I totally forgot that I tried building one until IIchecked the website
moocow
Vancouver, BC
I had one using P45 chipset and Q6600. However, I was using the spec Gigabyte board that they recommended. It worked pretty well until I upgraded to Ivy Bridge built which is a bit buggy in terms of audio and USB 3.0.
MARSTG
Montreal
Snow Leopard works really well on just a C2D E8400 and 4 GB of RAM. A Geforce 8400GS or Radeon HD 5450 should give you the acceleration you need for QE/CI and some apps. VLC doesn't work without OpenGL acceleration, and QE requires OpenCL.
