I've played around with a number of settings on my router, but before I try a full reset as a last result (and sadly needing to resync all my google home stuff), has anyone run into this?
My S23 Ultra connects to wifi without difficulties, either with static or DHCP IP and the default MAC address or set to 'Phone' Mac. It maybe works for an hour but always eventually goes back to 'connected without internet'. It's annoying enough I generally just turn the wireless on the phone off entirely.
Most other devices seem to work, though my google doorbell does seem to disconnect periodically.
Debating if the reset is worth it, and if it doesn't solve it if my aging router might need replacement.
Router is an ASUS RT-AC3100, in 'Wireless router mode'. Wireless is set up as 'Dual-Band Smart Connect' with the smart connect enabled. Authentication is WPA2. WAN was set to automatic IP, but should I also try static?
Networking is my least savvy part of tech ownership so some suggestions to start troubleshooting are appreciated. I've never cared enough to look into it a lot.
