Videocardz reporting Galax is releasing a single slot 5060Ti with 16GB VRAM only. Cost $5K RMB which at the moment is $982 CAD. That's 50% more than the cheapest GB Windforce model at $600 CAD.
EDIT: it's using the good old 8pin!
videocardz.com
GALAX launches GeForce RTX 5060 Ti single-slot graphics card - VideoCardz.com
GALAX has a single-slot RTX 50 card Not really targeted towards gamers. Think 16GB of memory, but in a single-slot design. The closest you can get to that is probably the RTX PRO 4000 or RTX PRO 2000, official Blackwell workstation cards. The difference is that they’re still dual-slot, though...
