Gigabit router - things to consider?
Mr. Cipher
London (UK)
Hi all,
I would like to get some suggestions on what I should look for in a gigabit router, and hear about any of your experiences with specific brands/models. I want to use it to hook up 3 computers that all have gigabit ethernet, so I can make my LAN faster, though I believe cat-5 only goes up to 100mbps.
Anyways, its been a long time since my CCNA days (pre-wifi), so I was hoping that anyone can bring to my attention anything that I should consider.
I am hoping that there is not too much to catch up on.
Thanks folks!
Cheator
Ottawa, Canada
Website
seriesoftubes.ca
Hi all,
Thanks folks!
You're not missing much from CCNA. There is no wifi coverage yet.
What I think you should consider is the price. If you have a current router now, and you're getting a router with a built in gigabit switch...why not just get a gigabit switch? Thats what I've done. It means that the gigabit computers are on their own switch and connect to the router just fine for internet.
Mr. Cipher
London (UK)
I only have a 100mb switch right now. I wanted to get the router to act as the wall between my Lan and the internet, and also to benefit from faster speeds on gigabit ethernet.
Normally I would not care, but it mMakes a difference since my new place has fiber-optic right to my jacks. Can't wait for gaming on that.
Cheator
Ottawa, Canada
Website
seriesoftubes.ca
So your uplink speed is greater than 100 meg?
