GIGABYTE GeForce RTX 2070 Super WINDFORCE PCB
LegendMask
Montreal
Does anyone know if its using FE PCB? I’m planning to get it but I need a 2070 Super that I will be able to watercool it.
Model: GV-N207SWF3OC-8GC
Cptn Vortex
Age
34
Vancouver
I know my 2070 non-super (also gigabyte Windforce) was 99% similar to the FE (I got a 2080 EK WB). One of the fan/RGB headers was in the way, so I pulled off the plastic connector housing and bent the 4 pins parallel to the board making sure not to touch anything, and it then fit fine. Link to a explanation: https://hardwarecanucks.com/forum/threads/asus-strix-rtx-2070.79182/post-884193
The 2070 Super is essentially identical to a 2080, so I think you should be ok, although I cannot find any tear-downs of that card in particular.
LegendMask
Montreal
Thanks Cptn, I did read that the 2070 GigaByte Windforce had the same 2080 PCB, which likely the 2070 Super will be the same, but it isnt sure i guess.
I just dont want to get it then get stuck with it not being able to watercool it :(
