Gigabyte Radeon HD 7970 3GB OC Review
Status
Not open for further replies.
SKYMTL
HardwareCanuck Review Editor
Montreal
AMD’s 28nm graphics cores in the HD 7970 and HD 7950 are without a doubt impressive and have the ability to either meet or surpass the competition’s high end offerings without requiring huge amounts of power. While availability of the HD 7950 seems to be quite good, finding a HD 7970 can be a bit tough, particularly if you are looking for a non reference version. This situation may speak volumes about the Tahiti XT’s popularity or it could signify a lack of regular stock replenishment but for the time being, Gigabyte’s HD 7970 OC is one of the hardest to find.
Gigabyte may call this an “OC” edition but the clock speeds aren’t all that impressive. The core clock has been increased to 900MHz –an increase of less than 10% over AMD’s original specs- and the memory sticks to default frequencies. Unfortunately, such a limited overclock won’t make any difference in the playability of games but it does allow for the possibility of Gigabyte releasing an even higher clocked Super Overclock edition sometime in the future.
Unlike some other mildly overclocked HD 7970s, Gigabyte has decided to deck their card out in a custom heatsink which is meant to lower temperatures, thus increasing the likelihood of users successfully increasing clock speeds even further. Otherwise, the HD 7970 OC sticks to a mostly reference layout with a length of 11.5” and a pair of Crossfire connectors.
Some may be in for a bit of sticker shock when they realize this particular graphics card goes for a hair over $600USD at many retailers, bringing it in line with XFX’s Black Edition DD and ASUS’ DirectCu II. Unfortunately, this is the price you’ll need to pay for a custom cooled, mildly overclocked HD 7970 these days, provided you can actually find it in stock.
The popularity of Gigabyte’s card isn’t due to its high clock speeds but rather the Tri Cool heatsink that has been installed onto this HD 7970. The Tri Cool design is essentially a rebranded Windforce 3X and has all of its predecessor’s defining features like a trio of intake fans, an extensive internal aluminum fin array and several large copper heatpipes. It has a ton of thermal mass and in previous reviews, the temperatures it produced were impressive to say the least.
Alongside the HD 7970 OC’s outer edge is a long piece of metal which is used to stop the PCB from bowing under the heatsink’s weight. We can also see that Gigabyte has kept AMD’s Dual BIOS switch but unlike some Sapphire designs, only one BIOS is populated while the other can be loaded with a user-defined profile.
Since Gigabyte has used the underpinnings of a reference PCB for our early release card, output connectors and power inputs have remained the same as we have seen with all other HD 7970 cards to date. For whatever reason though, Gigabyte won’t be including ANY adaptors other than a DVI to VGA dongle which means you will have to purchase additional components if an Eyefinity setup is ever used. This really doesn’t sit well with us since this is of course a $600 graphics card and AMD stated that all HD 7970s would come equipped with the connectors necessary to run Eyefinity.
It may look like Gigabyte has moved away from their typical blue PCB and decided to go with the reference black design. However, this is an early sample and uses AMD’s reference design since the actual retail PCB wasn’t ready in time for the pre-launch date. Mass market products use a custom Gigabyte design with their typical blue colour and Ultra Durable VGA features like a 2oz PCB and a slightly different component layout.
Test System & Setup / Benchmark Sequences
Main Test System
Processor: Intel Core i7 920(ES) @ 4.0Ghz (Turbo Mode Enabled)
Memory: Corsair 3x2GB Dominator DDR3 1600Mhz
Motherboard: Gigabyte EX58-UD5
Cooling: CoolIT Boreas mTEC + Scythe Fan Controller
Disk Drive: Pioneer DVD Writer
Hard Drive: Western Digital Caviar Black 2TB
Power Supply: Corsair AX1200
Monitor: Samsung 305T
OS: Windows 7 Ultimate N x64 SP1
Acoustical Test System
Processor: Intel 2500K @ stock
Memory: G.Skill Ripjaws 8GB 1600MHz
Cooling: Thermalright TRUE Passive
SSD: Corsair Performance Pro 256GB
Power Supply: Seasonic X-Series Gold 800W
Drivers:
AMD Beta for HD 7900-series (January 20th)
AMD 12.1 WHQL + CAP 11.12 CAP3
NVIDIA 285.62 WHQL
Application Benchmark Information:
Note: In all instances, in-game sequences were used. The videos of the benchmark sequences have been uploaded below.
Battlefield 3
<object width="640" height="480"><param name="movie" value="http://www.youtube.com/v/i6ncTGlBoAw?version=3&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/i6ncTGlBoAw?version=3&hl=en_US" type="application/x-shockwave-flash" width="640" height="480" allowscriptaccess="always" allowfullscreen="true"></embed></object>​
Crysis 2
<object width="560" height="315"><param name="movie" value="http://www.youtube.com/v/Bc7_IAKmAsQ?version=3&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Bc7_IAKmAsQ?version=3&hl=en_US" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>​
Deus Ex Human Revolution
<object width="560" height="315"><param name="movie" value="http://www.youtube.com/v/GixMX3nK9l8?version=3&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/GixMX3nK9l8?version=3&hl=en_US" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>​
Dirt 3
<object width="560" height="315"><param name="movie" value="http://www.youtube.com/v/g5FaVwmLzUw?version=3&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/g5FaVwmLzUw?version=3&hl=en_US" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>​
Metro 2033
<object width="480" height="360"><param name="movie" value="http://www.youtube.com/v/8aZA5f8l-9E?version=3&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/8aZA5f8l-9E?version=3&hl=en_US" type="application/x-shockwave-flash" width="480" height="360" allowscriptaccess="always" allowfullscreen="true"></embed></object>​
Shogun 2: Total War
<object width="560" height="315"><param name="movie" value="http://www.youtube.com/v/oDp29bJPCBQ?version=3&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/oDp29bJPCBQ?version=3&hl=en_US" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>​
Witcher 2 v2.0
<object width="560" height="315"><param name="movie" value="http://www.youtube.com/v/tyCIuFtlSJU?version=3&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/tyCIuFtlSJU?version=3&hl=en_US" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>​
*Notes:
- All games tested have been patched to their latest version
- The OS has had all the latest hotfixes and updates installed
- All scores you see are the averages after 3 benchmark runs
All IQ settings were adjusted in-game and all GPU control panels were set to use application settings
3DMark 11 (DX11)
3DMark 11 (DX11)
3DMark 11 is the latest in a long line of synthetic benchmarking programs from the Futuremark Corporation. This is their first foray into the DX11 rendering field and the result is a program that incorporates all of the latest techniques into a stunning display of imagery. Tessellation, depth of field, HDR, OpenCL physics and many others are on display here. In the benchmarks below we have included the results (at default settings) for both the Performance and Extreme presets.
Performance Preset
Extreme Preset
Battlefield 3 (DX11)
For this benchmark, we used a sequence from the Rock and Hard Place mission. The results may seem lower than normal and this is due to the fact that after playing through the game multiple times, this one are was found to be the most demanding on the GPU. As with all of the tests, we try to find a worst case scenario in order to ensure a given card can properly play through the whole game instead of just a “typical” section.
1920 x 1200
2560 x 1600
Crysis 2 (DX11)
Crysis 2 (DX11)
Crysis 2 with the DX11 and Texture Package installed not only looks great but it is a strain on any GPU. For this benchmark, we used a classic runthrough which includes far views, explosions, combat and close-in knifing; basically every hallmark of gameplay.
1920 x 1200
2560 x 1600
Deus Ex: Human Revolution (DX11)
Deus Ex: Human Revolution may not be the hardest game for today’s high end gaming rigs to render. While the game mostly takes place indoors, it is the few outdoor areas that put additional strain on graphics cards. So for this test, we use one of the more involved outdoor sections: the Sharif Manufacturing Loading Docks.
1920 x 1200
2560 x 1600
Dirt 3 (DX11)
Dirt 3 (DX11)
Dirt 3 isn’t all that much different from its predecessor but the developers have added a few more visual touches but boost image quality. In this case, we used the Michigan Rally track since it features some of the hardest to render features of the game: expansive vistas, water, dirt effects, trees and many other items.
1920 x 1200
2560 x 1600
Metro 2033 (DX11)
Metro 2033 (DX11)
For this test we use a walkthrough and combat scene from The Bridge level which starts at the beginning of the level and lasts for about 3 minutes of walking, running and combat. Famerates are measured with FRAPS and Advanced PhysX is turned off.
1920 x 1200
2560 x 1600
Shogun 2: Total War (DX11)
Due to its very nature, Shogun 2 is a tough game to benchamark since the in-game tool doesn’t accurately convey an in-game experience. So we took a pre-recorded battle which pits three large armies against one another and includes camera zooms, fog, gun smoke and other items. Using a pre-recorded sequence also effectively removes the CPU from the equation since it doesn’t have to process AI.
1920 x 1200
2560 x 1600
The Witcher 2 (DX9)
The Witcher 2 (DX9)
The Witcher 2 may be a DX9 based game but its graphics quality is beyond reproach. In this benchmark we take an area out of The Kayran mission and include one of the toughest effects the graphics engine has in store for the GPU: rain. Throughout this sequence, rain plays a large part but explosions, combat and even some sun shafts are included as well.
1920 x 1200
2560 x 1600
Status
