Gigabyte Z77X-UD5H Error 96
Alpine
Boucherville / South shore of MTL
Hi guys,
I have a question about a pc without display since few days.
The led error code give the code 96, which is '' Assign PCI device resources''
How do i do that '' Assign PCI device resources '' when i have no display ?
This probably useless, I have try other video cards, monitors and PCI slot, still nothing appears.
Thanks
sswilson
Moncton NB
Have you done the standard "remove all unnecessary hardware/single stick memory/cmos reset" yet?
Alpine
Geokilla:
I am not able to access the bios. I don't have any display. Monitor stay off. Also, since this board have a dual bios, i switch to the second one and i still have the same error.
Valkyrie
Chilliwack...Time Is Just A Rubber Band....
You could try closely examining the socket and applying a little deoxit to the land pads of the chip and re-seating (or even just re-seating.) It might bring it back or it might be a hard fault. Long shot but maybe worth a try.
Valkyrie
That's interesting Alpine. I'm curious as to how long you had the board completely powered down when you changed the battery. It seems something was latched up in a bad state and being held by a capacitor.
Glad to hear your back in business...
