GPU Throttling and coil whine
amateur101
Member
Hi I have a 5970 and a 7970 both with waterblocks on them and I recently switched out the 5970 for the 7970 but I still get throttling, is it because I'm running too many displays? My set up is currently 2 1920x1080 60 hz monitors and 1 144 hz monitor. Previously on my 5970 I was running 3 60 hz displays and it was throttling really often and now with my 7970 I added in a 144hz display and it is throttling. Is the throttling for the 7970 caused by the 144 hz monitor or other problems? Also my 7970 has a real bad case of coil whine so I was hoping if anyone knows a fix to it.
EDIT
Specs,
CPU : i5 2500k 4.5ghz
Ram: 8gb corsair vengeance
PSU EVGA 650 Watt 80 plus gold
Mobo: Asus P8Z68-V Pro
amateur101
Member
Specs has been posted @CLShade
@Bond007
It starts to throttle outside of games usually watching videos but sometimes it throttles in games for a short bit.
clshades
Calgary
Bond007
Nova Scotia
@Bond007
So there isn't an impact on gaming for the most part? When you say throttling to you mean things are stuttering, or that you have confirmed the video card is lowering frequency?
clshades
Calgary
Ok I did some googling around. You need between 31-36amp rails minimum. If you want to OC you need more. I'm sorry your PSU is not sufficient @ 20amp. Good thing it started whining or you wouldn't have noticed.
Shadowmeph
I never knew that you could get coil whine from insufficient PSU I learned something new :)
Bond007
Nova Scotia
I am not so sure the psu is the only issue (though it may be), since he said the issue doesn't arise under load in game, but in video watching. That would push me toward a driver issue.
