I took apart the watercooling loop so I can access the motherboard to swap a NVME drive under a cover. After I put everything together and used a hand air pump to pressure test, it start leaking at the connector bridge after I pumped too much air into it. Even at 0.5 bar, it would leak (the residual fluid was creating bubbles). Anyone have experience rebuilding the gasket or o-rings inside an EK GPU waterblock? I'm looking for some guidance since my current plan is to take it apart, measure the o-ring thickness and order some replacement online. Also, any tips of cleaning the blocks, pumps, and rads once they are outside of the case? I left the fluid in too long and the dye degraded and stained the tubes.
