H105 Waterblock Cleaning and Applying Thermal Paste Question
appplejack
Toronto
I just bought Corsair H105 for Intel Core i7 1150 with Asus Maximus VII MOBO.
I bought Arctic 5 paste so I can use it for the CPU and the waterblock.
The problem is that H105 waterblock has already have thermal paste applied on it. What can I do to ensure the surface is clean? Can I just use my rubbing alcohol and lens cleaner?
Also can I follow the thermal paste guide presented on Arctic Website?
http://www.arcticsilver.com/pdf/appmeth/int/vl/intel_app_method_vertical_line_v1.1.pdf
Thanks
TTC
I've always used rubbing alcohol and some microfiber cloth.
appplejack
Toronto
Thanks.
I just used some microfiber cloth but it left some tiny scratches (visible but not much).
I think there was some small particle on the cloth itself.
I cleaned the surface but I hope it doesn't affect it too much.
sswilson
Moncton NB
I prefer 99% alcohol as I know there aren't any oils or added water. As far as my lint-free cloth goes... I just use paper coffee filters.
AkG
An old pair of CLEAN cotton socks (turn it inside out) works very well to. ;)
ZZLEE
KANATA
Toilet paper is a usefull initial wipe also then Alchol whipe if you have one.
appplejack
Toronto
Thanks for the tips. I installed H105 on Haswell 4790K on Maximus VII Hero.
The idle temp (realtemp) is higher than I expected (around 37C with no overclocking).
Is this too high? Should I reapply the thermal paste?
Also I found that the fans come with H105 are rather too noisy. I think replacing them with Noctua Silent fans will be a good idea.
