Half Life 2 odd issue
fightingfi
I contacted steam they seem to not be able to help even though its there game...........Everything you can think of on a pc and mine is updated with newest drivers...but i get this now after hl2 did its new update
The first one suggests potential shader issues as a trigger panel should obviously not be visible.
Gigabyte B650 Aorus Elite AX motherboard
Sapphire 7900 GRE NItro Edition
AMD 9800x3d x3d isnt used yet.....
32 gigs of ram teamgroup ddr5 6000 CL 30 stock
WD_BLACK 1TB SN850X NVMe​
Seasonic 1300 PSU
nothing is overclocked
I replayed it recently too and had one such issue: the fight at the lighthouse after the car level, just before Sandtraps I think. The glass around the lighthouse bulb had a pink and grey checkerboard pattern. I think it was because I loaded that map manually because I'd been through there already without any issues. Seems like the game gets confused when you do things out of order. Did you do anything like that?
NO i just played it from the Begining after the new updates were applied for the 20 yrs of hl2
