HALP! i7 build issues!
ImmaPC
Burnaby, B.C.
Alright, so I FINALLY got the RAM here for my i7 setup today, and was so excited that I couldn't wait to buy a new case for it. I set it all up on a temporary cardboard box that my motherboard came in. I turned it on the first time and the CPU heatsink fan, 4850 fan, and PSU fan spun a tiny bit, and then this orange LED turned on and it stays on until I switch off the power (obviously). Has someone ever had a problem like this? Anyone have any advice?
BTW I got a youtube video currently uploading to give anyone a clear picture of what's going on. I will update with link when it's done.
Babrbarossa
New Brunswick
Maybe memory problems- is it an ASUS P6T? make sure memory are in the right slots- try booting with only one stick.
ImmaPC
Burnaby, B.C.
Actually it's eVGA X58, sorry for forgetting specs. CPU is just i7 920, RAM is 6GB OCZ Gold XTC DDR3-1600 8-8-8-24. Booted with one stick, made sure RAM is in proper slots.
I got youtube video of what's going on:
YouTube - i7 Problem AHH!
3.0charlie
Bedford QC
Reset CMOS, remove battery for 30 seconds. Double-check electrical connections, especially the 8-pin EPS connector.
ImmaPC
Burnaby, B.C.
^ Check. EPS is DEFINITELY in, as well as the 24-Pin (forget what the power connectors are called). Cleared CMOS, took out battery, still no dice.
Chilly
Ontario
Double check that there are no shorts in the cabling, try with only 1 stick of ram, try with the video card in a different slot.
Infiniti
Vancouver, BC
I'm pretty sure that the orange LED is suppose to be on, since it is on for me right now too. Try using another PSU, though I doubt it is, since the light goes on even when it turns off. It might be worth a shot though.
ImmaPC
Burnaby, B.C.
Great, lol that PSU is the only one I got with an 8-pin EPS connector instead of 4-pin...guess I gotta borrow one off my buddy.
I'm praying the damn thing isn't broken, it was expensive and do you need the receipt for an RMA cause I forgot where I put it... :(
Infiniti
Vancouver, BC
For the RMA, depending on the situation, you'll need the receipt. If you bought it from NCIX, they might be able to find your invoice, especially of you ordered online.
For now, try using your current PSU to power the i7 system. You don't need to take it out, just plug it in the necessary things to power the system.
ImmaPC
Burnaby, B.C.
Yeah, that's what I'm doing but it doesn't seem to be working. Might I ask, if it were the PSU malfunctioning, then why does the blue LED by the 24-pin connector come on when I switch on the PSU (indicating that there is power to the motherboard)?
And actually I went to the store and paid in cash for the thing, would they be able to retrieve a new invoice for me given that scenario?
