Hard drive not displaying correct size
belinik
mtl
Got a wd green 1.5tb sitting with me for 2 month as my backup and finally decided to use it. Plugged into my main rig and instead of showing 1.4xxxtb windows is showing it has 500gb ish. I tried replugging and restart computer and it's the same. It is partition under MBR using windows vista and I do have other 1.5tb drive running without issue.
What should I be looking at?
belinik
mtl
windows and bios is showing incorrect size at the same time, even tried format repartition restart, different sata port.
Called wd tho and they suggested RMA, which I did. Thanks for the advise tho :D
