Hard resets under 3D load
SugarJ
Langley, BC
OK folks. I'm looking for help with an issue I'm having.
X58 Classified
920 D0 @ stock
Xotac GTX 470 @ stock
Silverstone Strider 850w
System is GPU and CPU folding stable. When I start a game and leave the menu (i.e. go into 3d mode) system performs a hard reset with no BSOD. Does the same with OCCT GPU test.
So, what do you think the issue is? GPU or power supply? Something else? My problem is the WC loop makes it very hard to swap out the GPU easily. I've got a 9800GTX and Coolermaster 850w in my wife's E8400/P45 machine I can scavenge to swap out for testing. I don't have another i7 or any DDR3 mem I can swap out.
sswilson
Moncton NB
If you've got another PSU you can swap in with minimal hassle (you could even just jumper the second PSU and use it to power the gpu) that would be the obvious thing to try first.
Really sounds like a GPU issue of some form to me though, especially if the cpu is Prime / Folding stable, although I'm not sure what to think about it being GPU folding stable.....
SugarJ
Langley, BC
Oho, I've even got a dual-psu cable that came with my TJ-07. That would save tons of time. Great idea, thank you Mr. W.
I'll report back shortly.
enaberif
Calgahree, AB
Have you setup windows to not reboot on BSODs??
You could be getting one but it reboots or shutdowns before you see it?
Power is a definite thing to look into.
SugarJ
Langley, BC
OK, dual PSU setup, and now the resets don't happen. It was happening within seconds of starting OCCT's GPU test, and now just ran 10 minutes at max loading with no issue on the 2nd PSU. Further testing is needed, but that seems to be the issue.
I think my Strider is toast. Which sucks, but that's much better than it being my 470. I'll post a picture of my Frankenstein setup in a couple minutes.
And enaberif, the lights on the mobo were going out. I think it's the old capacitor slowly dying thing. Too much draw, the 12V line voltage drops and the board resets and POSTS. As soon as it resets, the draw is gone, so it will boot normally.
Edit: FrankenPSU setup picture:
_dangtx_
mtl
very interesting. how old is the unit? tru the grill can you spot anything? some dude called me over +- something similar, he had a TON of dust in there so i guess it was overheating? :)
SugarJ
Langley, BC
It's about a year old. I can't see any bulging caps. And my computer gets the dust blown out of all the fans and grills monthly if not more often. Ambient in my basement is around 22, so I can't see it overheating.
_dangtx_
mtl
okee, so it basically started doing it out of the blue? i suppose you have decent power protection going to the wall before it hits it right?
lowfat
Grande Prairie, AB
I started doing the same thing here. I was baffled how my system would reboot itself everytime I folded & ran all GPU's at load. Until I threw another 1050W PSU in to the picture. My 1000W Antec Quattro doesn't even have an 800W load on the PSU either.
Perineum
Surrey, B.C.
I don't know exactly where you are in Surrey, but my 1000W and 850W PSUs are just a phone call a way if you don't feel like tearing down your other systems to get at a PSU in the future.....
