Have to reset LAN Adaptor always-Help
Malam
Toronto
I am having to reset my LAN adaptor (Realteck RTL8168) everytime my computer wakes or is restarted from sleep or hibernation. I am not sure why this is happening. I have a Netgear Wireless Router WPN824 connected to a DSL modem. Disablying Zone Alarm does not help. Any ideas please? Motherboard is GA-P35C-DS3R and I have tried both Vista and XP no difference.
Thanks.
3.0charlie
Bedford QC
When Windows goes into a Sleep state, it shuts down hardware - and once awaken, "forgets" to bring those back online.
I believe that in Device Manager, under the LAN Adaptor Properties there is an option to change the adaptor to being available under all Windows states. I "think" that's where it is.
binkenaid
Member
you can make a small script to disable and re-enable the desktop its not the best but its faster than manually doing it
open a notepad and type ipconfig /release then the second line ipconfig /renew and save it as .bat insted of .txt
then run it when your pc comes out of sleep.
as i said again its not the best soultion but its the other option :p
