HDD not Reading in OS but will in Bios ?
r0k0
Gatineau, Quebec
put some parts together for a cheapo build from left over parts
Asus P8H67-M Pro
Intel I3-2100
2x 2GB Corsair Value
anyways, i have 3 Spare HDD, 160GB SATA, 500GB SATA, 1TB SATA from Seagates, when in Bios you can see the same and size and i can choose either that or USB Key for boot
i use the USB Key to run 1st to install Win 8.1 and everything goes well until i have to select a drive where to install Windows.. and nothing shows up
any clue what's up ?
ZZLEE
KANATA
Format the drive.
Custom install / remove partitions / format drive.
Only have your C: drive hooked up when you install no other drives.
You may have to mount the drives on a working PC first.
r0k0
Gatineau, Quebec
i couldn't do anything for the partition or formating, but i'll have to put on my main pc and format the drive and try again
bignick277
Go to Control Panel -> Administrative Tools -> Computer Management
When the Computer Management application starts, in the left hand column select "Disk Management". Wait for Windows to populate the list in the middle column, bottom half.
If your BIOS detects the HDD but windows doesn't, it should appear in this list. Find the HDD in this list. All you should need to do now to get access to the drive is assign it a drive letter by right clicking the entry and selecting "Change Drive Letter and Paths". You can also reformat and repartition the drive using this application. Remember this tool in windows as it is the primary disk management tool for Windows OS's, and easily one of the most useful. So take note of it for future reference.
Just be aware, that if the drive is using a non-windows format such as Linux's Ext4, then windows will not be able to mount and use that partition. It can see the drive, (it can even cause hangs when booting windows while windows can take a long to time to figure out it can't use it before giving up)., it just can't use those partitions while in windows. So if you want to use HDD's that have those partitions on them, then you will want to repartition and reformat the drive in question.
Hope this helps.
jalmir
Montreal
Hope this helps.
That would work if he had Windows already installed, re-read his post, OP is trying to install Windows and the HDD don't show during Windows installation.
jalmir
Montreal
Asus P8H67-M Pro
Intel I3-2100
Try downloading the SATA drivers for that motherboard on your other PC, then copy the drivers in a folder on the USB drive that has the Windows installer.
When you're on the window to choose the drive click "load driver"
From there you should be able to browse ot the folder with the drivers and see the HDD. Good luck! :thumb:
bignick277
Oops. You're right. Sorry about that. threw my back out yesterday and on strong pain killers. Got confused.
