HDMI and no sound
Wurmer
Montreal
Here is my problem,
I have a BenQ monitor with and HDMI port. Normally, I'd use a DVI connection to hook it up to my computer and everything would work fine. Since I had a HDMI lying around doing nothing I said hey what the heck, lets use it for my computer. I have got the video working but no sound.
Here some details :
OS is XP updated to the latest
Sapphire 4870 with and HDMI to DVI adapter. HDMI cable from Monitor to GPU.
ATI Drivers and ATI HDMI Drivers, latest version.
When I go into the configuration Sound and Audio Device -> Audio -> Sound Playback -> Default Device -> ATI HD Audio Rear outpout I have no sound but when I revert back to Realtek HD audi output I get the sound working.
I am not sure what's going here, I thought that since this GPU supports HDMI I would get the sound working through an HDMI cable. Did I forget to connect something ? is there a connection between the GPU and MB that ought to be made for the HDMI to work ?
I'd gladly hear what you have to say about this, I am a newbie when it comes to this sort of things.
Arinoth
Halifax
To my knowledge there should have been a little 2 pin cable that came with the GPU. That needs to be connected to the SPDIF OUT on the motherboard, otherwise there will be really no way for the sound to magically jump from the motherboard to the GPU
Arinoth
Halifax
it only supports S-video, DVI, not HDMI connection
read manual
I just read the manual an no where does it say it does not support HDMI. You need to use the DVI to HDMI connection and apparently the audio processing is done onboard as well so with ATI cards i guess you don't need the spdif connection as you do with nVidia cards
sswilson
Moncton NB
That's for Nvidia cards, ATI cards have built-in audio for HDMI output.
read manual
Nope, it should be good.....
DVI-I Dual Link connection (It provides audio and video digital signals and HDMI™ output that is compatible with most HDMI devices.)
I'm assuming you've installed both of the files from this page..... ?
Drivers & Tools | GAME.AMD.COM
If that hasn't worked, then I'd suggest uninstalling all current ATI drivers and installing from the original install disk.
Arinoth
Halifax
Yeah, thats why after reading the manual KaptCrunch linked i posted an updated opinion/view on the OP's issue/problem
Wurmer
Montreal
Ok I think Ive figured it out ( slap behind the head) the monitor I am using is not equipped with speakers so that might explain the current situation does it not ?
sswilson
Moncton NB
Hehehe.......
Yeah, that'd pretty well explain the lack of sound coming from it..... :)
Arinoth
Halifax
Wait a sec, speakers are what create/produce sound, no way! good to see you at least figured out the problem
