I need to get a WIFI adapter for project nephew budget build. I have used a couple cheap USB ones in the past that were fine for the purpose (maybe TP-link or netgear?), but I have definitely not been tracking that side of things in a few years. It doesn't matter if its USB or pcie for the build, so it will just be what is the best bang for buck out there.
It does not need to be the latest and greatest, just a stable, reliable, fast enough connection. Hoping for ~$25, but a touch more is fine if it will be worth it.
At a quick amazon skim I found these, but options are obviously not limited to just these:
EDIT: I remember someone sharing a pcie based option from aliexpress some time ago, but I think it had issues with the stock antennas. Anyone remember details from that to confirm?
