Help me find a NB/SB block
moditir
Active member
As the title suggests I'm looking for a north brigde or /and south bridge water block for my P5K deluxe WIFI/ap I can't seem to find anything that lists it as a compatible mobo
do you know of any NB/SB water blocks that support the asus p2k deluxe wifi
thanks
moditir:canadianwave:
enaberif
Calgahree, AB
problem with these motherboards is you can't replace it without removing all the heatsink as the heat pipe is built into the block on the northbridge.
Might want to look at cooling your case off more if its too hot.
M
Misoprostol
Guest
I'm using a Swiftech MCW30 on my P5K Deluxe.
You'd have to bend the heatpipe to get it out of the way though.
I'm just using a little heatsink on my southbridge. I've never seen any evidence that water cooling the southbridge affects overclocking..
Apollo4g
Montreal
The MCW30 fits most boards, well you can make it fit some times :)
some other good ones are the EK NB blocks and the DD maze 4 is what im using.
No use for the SB really.
EK block link:
EKWaterBlocks.com SHOP
