help
i have a hot swap bay in my 650d case and every time i put my western digital caviar blue 320gb in there it disconnects my 1tb black storage drive. my system boots on a 120g vertex 3. any suggestions or fixes for this?
rchong
Member
Victoria, BC
have you tried switching the port for the 1tb drive?
with all 3 drives connected, check bios to see if maybe you can re-enable the 1tb drive?
thanks for the reply. the drive shows up in bios but it happens in windows. if i remove the hot swap 320 gb drive. the 1tb drive removes itself too. and it fixes once i restart. and if i add the drive to the hotswap while in windows it does the same thing. it removes the 1tb and keeps the 320 gig. ill try switching things around. hope i find a fix
:sad:
well ive switched the sata ports around on everyhting but my ssd and nothing has changed. so i have no clue what is wrong. it might just be the harddrive because ive tried the hotswap with an ssd and it doesn't do this. im still open for suggestions please :)
Adzsask
SK
Just grab an adapter and hook the 320GB drive right up to the PSU, not the hot swap bay.
kirbster
Courtice
I am assuming that you have the proper manufacturers driver loaded for the SATA controller? And it is set to AHCI to allow hot swapping?
Have a look, i had issues like this that were fixed by loading the proper driver instead of the Microsoft AHCI generic driver.
What is your complete hardware setup?
yeah ahci is enabled specs are gigabyte p67a-ud5 (b3) 2600k @4.5, dual gtx 580s coolermaster 1000w psu WD 1tb black sata 3, ocz vertex 3, corsair 650d, gskill ripjaws 2x4 1600
well i tried the hotswap with another drive, an ssd this time and it works flawlessly. but the hard drive still gives me troubles. might be a goofy drive. idk no loss really, i can always get a new one for cheapish when prices go down. hopefully soon :biggrin: thanks to everyone for their assistance. 'twas much appreciated
KaptCrunch
Ontario
have you checked the driver version of your chipset on MB.
i know ICH10R Southbridge has updates
also checked WD site for firmware updates of HDD's,
if are any updates remove all drives that aren't to be updated
and only do the updating in DOS to the drive thats needed
Note: back up DATA on drive before updating encase of failure of firmware
