Hot Deals!!!!!
supaflyx3
Langley, BC
It would be a great pfsense machine, however you'd be forced to use a usb NIC for OPT1 which isn't ideal. Overkill? Maybe a bit, but I use a Dell r210ii running esxi for pfsense so I'm a bit biased
Entz
Kelowna
With the extra M.2 and an adapter and a bit of modifications you may be able to squeeze a low profile card at the top. Say SFP+ or another port at least.
I am not sure too powerful is a bad thing as long as the idle power consumption isn't bad. You can consolidate all the security stuff and run all the services you want.
lowfat
Grande Prairie, AB
Pi4B 1GB $35 again.
Sagath
Folding Team
Edmonton, AB
$20/tb. SMR Technology, so fairly slow writes (40mb/s I'm told). Great backup drive for the $ though.
Great timing too, as I just filled up my old 2TB critical data NAS backup. :)
Izerous
Edmonton
I shucked a few 8TB externals while they were on sale for $99. Slow drive but similar idea for raw storage great way to go.
