How do i update my bios?
Bubbzilla
EDMONTON AB!!
I have an old P3 machine that I just got working. The mobo is the AOpen MX34. Im not really sure what the BIOS on it or how to check it. I don't want to mess it up... I have no harddrive yet but i have a CD Drive, Network Card, and Sound Card. Please help...
SugarJ
Langley, BC
If it's working, there is no reason to update the bios. Leave it be, it's tired.:biggrin:
tyreman
Cambridge, ON.
I went to the site found a bunch of stuff but if you wanted to update the cmos you'd need more info.
You can do all that.
If you don't want to mess it up what you typed leave...it alone.
KaptCrunch
Ontario
WARNING if not done a successful flash MB is DOA
just can't stop/back out of flash renders prom blank
flash from floppy in DOS use correct flasher and file and have reliable power source
who bios ami/award? can take a pic of boot screen....hit pause/break key to read
current version is R.19 bio date 1/26/2003 DieHard BIOS Lite supported
R1.18 10/21/2002 Supports EzRestore
R1.17 2/8/2002 best to have this version
R1.15 10/9/2001
R1.14 4/6/2001
R1.12 12/18/2000
R1.09 11/28/2000
R1.04 8/18/2000
R1.02 6/20/2000
R1.005/10/2000 Initial Release
check what version in lower left corner of screen
go here an read the fixes aopen D/L Selection: Motherboards>>MX34>>BIOS
sswilson
Moncton NB
If it doesn't fit, force it. If it breaks, it was never any freaking good in the first place!!! :)
rjbarker
Courtenay, B.C
Flashing the BIOS is fairly routine, however, even I "hold me breath" as if its not successful, the only option other than getting a new BIOS chip and installing on your Board is to RMA the Board.
Likely best to leave well enough alone, I only Flash my BIOS if my system is acting "funky" and a potential new BIOS version can alleviate the problem.
KaptCrunch
Ontario
no RMA here i'd hot flash with an extra chip if bio chip is socketed as a back-up chip encase something happeneds
