How do you remove a PCIE metal bracket?
Chris65478
Member
if any one knows how to do this it would be great if you could post a reply below or link me a video that shows me how :)
Chris65478
Member
like you know those things at the back of the case that are covered by metal until you insert a graphics card? i need to remove one of them and i dont know the safest way to go about doing that.
enaberif
Calgahree, AB
If its screwed in .. take out the screw.
If its attached to the actual case... You need to push and twist them out. Now if you have components in your case you need to be EXTRA careful to not scratch anything.
