how does heat affect cable?
Mr. Friendly
British Columbia
in this case, CAT6 or coax.
essentially I'm wondering if I should run my cabling up the wall corner, across the ceiling corner and back down the other wall corner to bypass any effect the heat / high temps from the electric register could cause, besides melting the coating / cover (hee hee).
anyone know?
sswilson
Moncton NB
It's not just melting you need to worry about... even if it doesn't actually melt the cover it'll probably make the coating brittle which can then break down easily potentially causing a short and/or allowing higher crosstalk between wires.
JD
Toronto, ON
Outdoor cable might survive a bit better, but yeah, I wouldn't run any cables near electric heaters. If you really have to, maybe put it in some conduit too.
gingerbee
Orillia, Ontario
I have 2x cat6 cable and 1x cat7 cable running right by my furnace and have never had a single problem, there are a few feet away from it but still always around 30c plus all the time
Mr. Friendly
British Columbia
yeh, not the same thing...a furnace tries to contain and force the heating through ducting while I have electric base heaters. the area around them gets so hot it's uncomfortable.
moocow
Vancouver, BC
Didn't know temps impacts attenuation. Per this article, Cat5e get 0.4% attenuation for ever degree C above 20 C. So placing it around a furnace or house air vents can cause problems. The jacket may survive 30 to 60 C (need to double check what's printed on the outside) but it may impact performance.
KaptCrunch
Ontario
Higher the temp less electrons flow through wire, the electric heater will have interference use STP cable
gingerbee
Orillia, Ontario
In fact, I live in an old warehouse and the furnace blows out right in front of itself its called a micro furnace I think it only has one duct going into my kitchen so the heat coming out is heating the cable up a lot and its way too hot to stand in front of this whole unit is in my living room.
The only way to heat warehouses that had the boilers removed is with electric/gas apt/furnaces this just much bigger, hits 40/45c in front
