how long to run system ( watercooling) testing?
Cowboy
Toronto, ON
its actually "yeeeeehaw" the "w" adds a little bit more of a redneck sound to it.
But that image you had was pretty funny, except I don't have a case :(
Sadasius
Ottawa
Doh....I will gitter writ nex time! :thumb: Haw not ha! Got it! LOL.
You have just an open bench right? What are you using if you don't mind me asking?
Cowboy
Toronto, ON
What do you mean? What am I using for my open bench? Well I've got a layer of anti-static bags followed by a layer of foam, followed by my motherboard, specs in sig.
Cowboy
Toronto, ON
well, its been working fine for about a month now, on and off. I see nothing wrong with it, the foam sheet has only a few indents in it from the backplate and a couple of protruding screws and hasn't melted or anything. Its pretty solid I think. Pretty much just used the packing materials that came with my board because it seemed like a better idea than just putting it straight on my desk or going out and buying an open bench.
If you want pics, just ask.
aviduser
Vancouver Island
I let mine run overnight. However I'm fairly confident with my setup that If I add a block or change tubing e.t.c that it wont leak. I've re-done my tubing about 3 times, and added rad's/blocks. The only time I've had a leak so far was when I accidentally used 7/16" T with 1/2" tubing.
Haha, and yeh its a little unnerving sleeping while leaktesting.
I actually had a nightmare that my pump fell sideways and wasn't getting any water (still worked fine afterwards tho :clap:).
3.0charlie
Laval, QC
I keak-tested the very first rig I ever plumbed. No leaks. Then I figured what could have gone wrong, and I make sure to follow the same procedure time and time again. Never had a leak.
Cowboy, I'll have a P182, a 902 and a HSPC Techstation available next week.
