How to build an APC U.P.S. data cable.
BrainEater
Calgary
Ok.
Let me start this out with a comment about this cable.
[rant]
For shame APC !
Doing the apple thing.....Proprietary cables to cash in....sheeesh.
35$ for this cable is theft.
[/rant]
Nice try tho..........I defy you !!!
The cable in question is the rj50 to USB data cable to connect an APC Uninteruptable Power Supply to the host computer.
This is a 10p10c modular phone connector.....looks like an ethernet plug but it's 10 pins.......that connects to a USB jack.
Donor USB cable + connectors ;
The pinouts can be found here : APC USB cable schematic pinout and signals @ pinouts.ru
Finished cable ;
That cost me 2$.
Srry APC.
:thumb:
MpG
Kitchener, ON
So this is just a general data cable that they decided to use a RJ50 head for? This really is turning into the new profit-booster for the technology sector. :blarg:
BrainEater
Calgary
yep.
They usta do db-9 (serial) type jacks.......then they went to rj-45's for a few.......it was then they realized the mistake of using a std ethernet connector , and switched to the rj50's.....to cash in... :sad:
Rj50's are actually becoming hard to find too....I had to phone 3 places before I found em at Active electronics.
The cable totally works !
It found new hardware etc....
I'm just gonna check out some software now....
:thumb:
lemonlime
Greater Toronto Area
Awesome!
I thought about doing this as well when I lost mine, but wound up finding it in the end. Wish they stuck with standard USB cables, but as mentioned, its pretty obvious that they are trying to cash-in on these at $35 a pop.
Eagle Eye
Kleinburg, ON
Still cost them even less based on the volume they produce them at, they're profit margins on those cables have to be in the 90-95 percentile.
SkyChief
Member
Toronto, Canada
My APC connection is a DB-9 and I have the APC 'signal' cable. This used to connect to my old PC. Now that I have a ASUS P6T Dlx and just realize there is no more serial connection jack anymore!
Do you think any of those USB to serial cable/adapter with the APC signal cable will work?
Obaid
New member
Obaid King
Friends i have a BACK UP CS 500...... and i haven't its USB port so i am trying to make it myself,,,,i bring connector and a USB wire now can someone tell me that there in USB just 4 wires and the connector have 10 pins so in which pin,,which wire should be inserted....plz plz plz help dearzzzzz
