How to connect a work laptop, personal use desktop PC and two monitors ??
Chess Gator
Hi fellows,
What is the best way to connect a work laptop, personal use desktop PC with two monitors?
I want to be able to seamlessly switch between using the work laptop and my PC without unplugging and replugging any connections!
Should I use a KVM, docking station or something else? In addition, which type? A link to the item(s) you recommend would be appreciated.
Please no cheap discount stuff only top of the line equipment!
Thank you in advance,
CG
What connection are you using on your monitors? Displayport, HDMI or a combination? The one you've linked has one DP and one HDMI out with the HDMI limited to 60 hz, I'd be trying to just use 2x DP personally.
Hi fellows,
I am using DisplayPort for both monitors. They both run at 4K 144hz
