How to set up HFM.NET and FahMon to monitor [email protected] progress. Now with videos.
Nodscene
Toronto
Hopefully, now I only have to wait about 24hrs to see if it updates it haha. In case it makes a difference I also changed the prefs in HFM.net with the proper info.
PerryC
Burton, NB
I was having a similiar issue, except HFM.net showed my normal folding username. Once the smp client started a new WU HFM.net showed the correct username.
Edit: for spelling, and currently can't check my [email protected] stats to make sure the WUs were turned in properly.....stupid government firewalls
geokilla
Toronto
Hey guys. I dunno if you knew this but FahMon got updated a couple months earlier and can now measure PPD bonuses. Back to HFM I go. I never liked HFM.NET.
Mathus
I'm using FAH Control on my desktop to fold my SMP and GPU and when I try to setup HFM.Net for my GPU it's not showing any progress. Is there [email protected] GPU data stored in a different location when using the FAH Client?
Mathus
I even tried the FAH Client folding in the following location but it doesn't seem to be registering.
C:\Users\Mathington\AppData\Roaming\FAHClient\work
SugarJ
Folding Team
Langley, BC
HFM.net is not compatible with the V7 client. If you set the user level to advanced or expert, FAHControl shows the ppd in the scrollable box on the right.
PerryC
Burton, NB
There is a new version of HFM out (0.90 revision 548) it now supports V7 client. When setting up your clients you have the choice of V7 or legacy V6.
