How to stop speaker feedback?
Chess Gator
Hi, I have a 2.1 set of Altec speakers. I have had them for several years. Now I am getting constant feedback from my speakers. It sounds like the radio when it is not on any station. Just garbled feedback noise~!
Do you know how to stop this problem?
I do have a sound card.
Thank you,
CG
Bond007
Nova Scotia
Did you try plugging them into something else (phone, etc) to make sure it is the speakers? Do you get a scratchy noise when volume knob is adjusted, or is it just a constant garbled noise? Checked all connections? Same noise from all speakers?
Shadowmeph
I think that I have it to it is more of the sound of air? in my case I can here a Hum. back in the day when people would hook up amplifiers in cars you would get a hum which meant it was ground issue I think that in this case at least for me it is also a grounding issue which I haven't been able to solve my stereos do the same thing if the volume is turned down I can hear like air ( a hiss) and also a low hum what I do for my 2.1 tv speakers ( which my PC is plugged into ) I turn down the amp volume on the speakers and use the volume control of the TV seems to solve the issue a little there is probably a way to ground out the speaker amplifier but I am not sure how to do this. on a side note I really notice the air sound when I plug in my headphones into the headphone jack on the 2.1 speakers which is also why I have never upgraded to a 5.1 sound system for my TY this building I live in is an older building so I think that it is some type of mild feed back because of lack of grounding
G
Guest
Guest
Have you tried plugging the speakers into another outlet? Not on the same circut as your computer?
Praktik
Active member
^^ this
Try speakers with another audio source. Some built in sound cards are very noisy.
If speakers play fine with another source I'd consider a decent USB audio solution to get the audio served up from outside the case/motherboard!
KaptCrunch
Ontario
try another set of speakers, mite be that ones using voice coils are burnt will do that of what you desribed gurbled
hum: grounding issues with power source or bad input cable with no ground
feed back check sound properties .... uncheck playthrough speakers
