HP bios is missing or corrupt
Eco
New member
My Laptops shows
What should I do
Plz help
My bios version is F.6A Rev.A
HP pavilion g6-1318ax
moocow
Vancouver, BC
How much is the laptop worth to you? You can either research on how to reflash the BIOS using a chip programmer or pay someone to do it. If the chip itself is damaged then your laptop is done. I recommend just remove the hard drive from the machine and retrieve the info if possible. If you are running Windows 10, the data in User directory may be encrypted.
