HP Mediasmart Server EX475
dARqSyDE
Ontario
Anybody got a suggestion for pricing on one of these?
No hard drives, 1GB RAM(+factory 512MB if they want it), one busted side panel clip.
JD
Toronto, ON
This is one of the original Windows Home Servers right? Are you including the OS with it?
If the OS is included, I'd say $200 would be fair.
dARqSyDE
Ontario
Yes, it is one of the original servers, and, while we can't resell software per se, I would happen to have an OEM copy of WHSv1 that I no longer need, and, should it fall into the shipping box.....:whistle:
JD
Toronto, ON
Glad you read the rules :thumb:
I would image there's a COA on the server though anyhow as I'm pretty sure HP shipped these with single drives and the OS pre-installed.
dARqSyDE
Ontario
Actually...I'm not sure about the COA...once I pull it, I'll check. But you are probably correct.
