Hp omen 15 R5+1660ti+60hz display Vs Dell g5 15 se Ryzen 5 +rx5600m+120hz screen
Shivin62
New member
Please do the Comparison of Hp omen 15-en0002ax and Dell g5 se Ryzen 5
In India we are getting Hp omen 15 white only backlit keyboard , Ryzen 5 4600h , 1660ti , 1080p 60hz screen as base variant (en0002ax) Vs Dell g5 15 se with Ryzen 5 , rx5600m, 120hz screen .
Please help me select the right laptop
moocow
Vancouver, BC
If I'm reading the configuration page correctly, then both of them are bad. It's 2021 and they are still defaulting to 8GB of memory? Not sure if you can even upgrade it yourself or the memory is soldered to the board. Windows 10 sitting by itself idle takes at least 5GB already. Start installing other stuff + the bloated pre-load software and you got no memory to use.
