HPET article.
Sagath
Edmonton, AB
I cannot say to know all the problems that this may be causing out there, but after reading the article and digging a bit on forums and Reddit this problem has been 'known' to cause issues for quite some time. The earliest confirmed problem I could find dates back to 2012, and I didnt even try hard to find earlier...Yet for all that this 'bug' is not WELL known in the PC industry. It affects Intel processors MUCH more than AMD. Upwards of 30% at 1080p resolution :shok:
https://www.anandtech.com/show/12678/a-timely-discovery-examining-amd-2nd-gen-ryzen-results
To ensure HPET is off run CMD with admin and type "bcdedit /enum"
If it does NOT return "useplatformclock Yes" as one of the categories, its off and you're fine.
Apparently this is reported on the net to cause anything from FPS drops, to studders, to USB problems galore...yet I'd never heard of it at all until this article today.
There is also talk that spectre and meltdown patches could be exacerbating the issue even further...
I'm really leaning towards an AMD processor next round. These 'quirks' and 'bugs' (or are they just 'features' so intel could retain its crown for longer?) are really starting to irritate me.
SugarJ
Langley, BC
HPET is disabled by default in Windows so it shouldn't be an issue for most people.
Lysrin
Nova Scotia
I checked the command and was disabled for me, as SugarJ suggested. Interesting article though.
Sagath
Edmonton, AB
Yeah. I thought I'd throw it up for search purposes. Might help someone fight a problem somewhere cause they accidentally flipped it on in the bios.
