I bought a 8400gs but my pc say is a G100
I don't think the seller rip me off but my PC say a total difference model and i did many updated including my bios hopping that will fix the problem but i am baffle
sswilson
Moncton NB
Not sure if it helps at all, but the 8400gs was apparently the lowest model of G100 card so you should be either on par or better no matter what. ;)
Well i bought some games and the PC i have a piece of sh*t and that how i bought a another PC and some part so i can play it but i was desperate
Gateway E-4500D bought off eBay is a a 400wPSU
Is have 512mb but is up to 2gb * left over part *
I add that video card * as i mention *
I add also a SB Live * left over part *
Now i want to drop about $20-$30 so is can be able to play current and mid-level gaming and is a socket 775 so there is a range of possibly
My wish list
CPU : Core 2 duo E7500/E7200/E6600
VC : HD5450 or HD6450
I thought i can post my setup so i can get some advice on can i improve my setup
<<< System Summary >>>
> Manufacturer : Gateway Corporation
> Mainboard : Intel D945GPB
> Chipset : Intel i945G/GZ
> Processor : Intel Pentium XE 930 @ 3000 MHz
> Physical Memory : 2048 MB (4 x 512 DDR2-SDRAM )
> Video Card : NVIDIA GeForce G100
> Hard Disk : Seagate ST3808110AS (80GB)
> DVD-Rom Drive : HL-DT-ST DVD-RW GWA-4165B
> Monitor Type : Spectre Sceptre - 17 inches
> Network Card : Broadcom Broadcom NetXtreme 57xx Gigabit Controller
> Operating System : Microsoft Windows XP Home Edition 5.01.2600 Service Pack 3 (32-bit)
> DirectX : Version 9.0c (May 2010)
I want to add also i can play Dishonored and Mafia 2 low/med setting however i bought LA NOIRE i learn the hard way because i thought is will be another GTA stamp but nope is lock at 30FPS same as a console and that the command to see any improvement nope nothing * however is does play but in a bad laggy way *
My wish list
VC : HD5450 or HD6450[/QUO
