I don't know what's going on with my GTX 970
sswilson
Moncton NB
Might also be worthwhile to uninstall Afterburner (and any other controlling software) on the off chance that it's gone rogue or is conflicting with a different program.
KaptCrunch
Ontario
agree remove any past or present video drivers and set to default display for a few restarts to clear out old drivers then get current drivers for your video card
also check MB drivers are up to date
clshades
Calgary
When weird shit happens with video cards after a long run from a different brand (AMD) to the new one (nvidia) it's time to format and start fresh. Until then u are ghost hunting...
Vittra
Ontario
Two things to do when switching video cards BEFORE you do the switch:
1) Uninstall any OC software you have (Afterburner, Trixx, etc) including any settings. You want to re-install it fresh so there's no conflicting settings and so that it detects your new card properly.
2) Uninstall old drivers completely, boot into safe mode, and run a driver cleaning program like DDU
If you've already installed the new card, that's okay. You will still follow the above two steps.
If you are still experiencing performance issues, but it is only a specific game, you can try changing that specific games application profile to "Maximum Performance" as has been stated earlier in this thread.
If you are STILL having issues, then you will definitely want to consider formatting and reinstalling the OS as has been suggested. I've never had to do something so drastic, but it doesn't surprise me that some people have had no choice.
It's important to keep in mind that even if it is the same brand that you've switched to, different architectures can still act oddly with old software/registry entries still present on the machine.
I've switched cards more than I'd care to admit in the past 4 years (including multi-gpu setups) and following the above routine has resulted in minimal difficulties experienced.
clshades
Calgary
Yep totally agree with the above post. Sometimes hours or days of trouble shooting are remedied with a format.
estKoncept
Member
Thanks all for the help, I decided to just go ahead and reformat and it seems to have fixed the problem! Now, is there a way I can mark this solved or something?
MARSTG
Montreal
No, we don't have a system like on Yahoo answers, we can see what you have chosen to do as fix, is enough.
sswilson
Moncton NB
Glad to hear it's resolved. Sometimes a fresh install is just the easiest and quickest way of resolving an issue like this. Especially when a full install is relatively quick.
