I need help with the BSOD issue
Prolab
Brampton
Okay, so for the past few weeks ive been having problems with my rig BSOD whenever i play BF3.
This what i have done so far:
- Used 11.11a,b,c and 11.12 AMD CCC with no avail
- Tested each 4GB module with memtest for a min of 12 hrs without any failures
- Passed Prime95 blend for 12 hrs+ using stock optimized default and OC
- Updated all drivers/OS
- Fresh install of windows 7 twice
- Used only one RAM module and yet still BSOD
- Updated PB
- Used (1) video card
- Updated FW on Crucial M4 and OCZ SSD
And i still keep BSOD only on BF3. It varies between 20 mins to 1.5 of gameplay and it still BSOD. Im running out of patience and i want to burn this rig down! :angry2:
I'll add the minidump file to my post... I dont know how to read it, so im someone could help me decipher it.. :sad:
I can only attached the first mini dump, the second is too big to attach. Here's the dropbox link:
http://dl.dropbox.com/u/6792158/Complete mini dump.txt
Prolab
Brampton
ok, ill try that. But if anyone could check my minidump, much appreciated, thanks!
Prolab
Brampton
Thanks for the help. It was actually my OC.
I needed to add more voltage to push it to 4.1. Which is weird since it past prime for 12+ hrs or so.
clshades
Calgary
I had to re-install to fix my bsod problem. It was related to old bad sound driver files with the auzentech prelude.
I haven't had any issues since i formatted.
