i need help
btu_mr_tea
Member
quebec
sorry for sunding dumb
but i have been reading u guys a bit and i think i can trust your opinions
i just bought myself an hp m7760n (e6400 2.13ghz, 2 gigs ram, 500 gig hd) with no video card
i want a high performance long lasting system for online gaming and the like(my old ones over 7 years old and still usable). So I m leaning towards an nvidia 8800 gtx + 2 xtra gigs of ram. I ll need a power supply to but i know nothing about those(the hp s an 300 or 350 w i think).I m also out of the loop for compatibility processor motherboards ect.. i need your inpt please.
thank you
Supergrover
Okanagan Falls, British Columbia
Okay how much do you have to spend? So you are looking to purchase 2 more gigs of ram and a new gfx card plus psu. gfx are going to drop with the release of the 86xx/89xx so you might want to keep that in mind.
PSU I like fsp psus good bang for the buck but again how much are you looking to spend?
btu_mr_tea
Member
quebec
well i know the 8800 gtx around 600 to 800 and well ram s 180 to 280
and psu i have no idea
i guess 1000 to 1500 would be my max(canadian dollars)
Babrbarossa
New Brunswick
As you know, the biggest performance gains you could hope for would come from a new GPU and overclocking your CPU- but from what I hear, overclocking is out of the question on the proprietary pc that you have- sswilson or supergrover might be able to confirm this, but your bios is probably locked up.
This may not be possible, bit if you're looking for max performance, and you JUST recently bought that pc from somewhere like futureshop, I would return it for refund and start from scratch as you'll have a much better system if it's based on a better motherboard. Don't be alarmed by this suggestion because there's certainly nothing wrong with your system, and with a good gpu, it will certainly be kick-ass!
As for the Ram-- if you want to save money, I wouldn't bother buying two more gigs at this point- you won't see a great performance increase at this point for the expense.
As for the 8800gtx GPU- I would make sure that it will fit inside that case, as sometimes those prebundled pc's from the big makers are pretty tight inside and those cards are really big.
For the psu, I would go one of two ways-- buy a decent 550W psu that will do you fine for that system, or you could go for something beefier that might do for your next build as well-- but where you only buils every six years, and you won't be overclocking on your current system, I might goo the 550 route and save some money-- let me know which route you think you'll do and I'll make some suggestions
btu_mr_tea
Member
quebec
since i really dont know enough about overclocking and no one around here could help me. i think i ll keep this system(good guess on the future shop:thumb:
unless its considered crap(like i said my last system was an amd athlon 750 k2, it was tweakable) so this is a major upgrade for me.
as for the power and gfx card i just wanted something that this system will handle for as long as possible.I guess i m really looking for a system ment for gaming that will support a good 5-8 years in the future.(not necessarly at the best resolution/settings).I m just aiming at the big stuff cause technology usually jumps quite fast nowadays.I really appriciate your inputs
again thanks so much
Babrbarossa
New Brunswick
Nothing wrong with your system at all!!
Here's a good power supply- it a 700w OCZ GameXStream and it's $117- it's lots of power for your purposes, but it's not much more money than 550's and 600's so probably a good bet.
What kind of RAM do you have? do you know what the specs are?
btu_mr_tea
Member
quebec
sorry for my ingnorence but the most i can tell you is DDR2-SDRAM PC2-4200 (533MHz) 2048 mb (2x1g)
xtra question my fsb says 1066 MHz vs ram 533 there must be room for improvment?and also installing a power suply only consist of unplugging and replugging the new one(+ physicly repacing them)right?
Supergrover
