I'm having problems with my printer
BootlegUsher
Hello, recently I starting having the issue where my printer isn't talking to my PC anymore. The printer is connected through a USB connection.
My first thought was to check the cable connections. They are fine. Next, I tried uninstalling and re-installing the software. During the installation I receive this error message: (see attachment).
I clicked on devices and printers and see this: (see attachment).
When I trouble shoot, I see this: (see attachment).
When I click apply the fix, I see this: (see attachment).
I thought that the network controller is something I would find on my motherboard's manufacturer website, here: ASUSTeK Computer Inc. -Support- Drivers and Download Z87-PRO
But I installed everything I see on that list and it didn't fix it.
I think that if I get this network controller installed that will solve my problem with the printer. Any thoughts or ideas?
SKYMTL
HardwareCanuck Review Editor
Montreal
Is the printer connected through USB 3.0 by any chance?
KaptCrunch
Ontario
wonder why it's looking at network for connection not usb
what OS ....... 32 or 64 bit
SKYMTL
Montreal
Yes it is.
Is it the USB port just to the left of the audio connectors? If not try those as they run directly off the PCH. The other USB ports use an ASMedia chip which has been known to cause compatibility issues.
I would also download the latest chipset drivers from ASUS alongside the newest ASMedia drivers. ASUS actually recommends you run printers off of the ASMedia ports though.....
BootlegUsher
64 bit windows 7
I tried all of the different USB ports but it doesn't help. I think the key to this is installing the network controller that windows says is missing. Like I said though, I installed everything on the Asus website for my motherboard. My printer has wireless connectivity, so maybe I'll just have to go that route.
Shadowarez
Arctic Canada
Iv had issues with my Pixma printer as well no comps would see it even if latest drivers. I plugged it into Usb on my router now all my comps see it and can print to it.
enaberif
Calgahree, AB
64 bit windows 7
Have you actually installed the proper drivers for your printer?
Seeing that it was searching "Windows Update" makes me wonder if your just using default windows drivers? Which is a BIG no no.
SKYMTL
Montreal
Another option is that your printer is actually using its wireless mode and can't find your computer on its network. Hence why it is throwing a network error into Windows.
BootlegUsher
The error message that you see in the first screen shot is during the installation of the printer software, using the CD that came with the printer. I have found the same software on Brother's website, and I get the same error using that too.
The only thing that changed in my set up is I upgraded from AM3 790fx to LGA 1150 Z87. Now that was a couple of months ago, and the issue with the printer only showed up two days ago.
When I uninstall the Printer and disconnect it from the computer, the blue box icon still remains with the orange triangle indicating a problem. TRAPPERKEEPERV2 is my computer name, it's a South Park reference. I can't help but think that if I figure out how to fix the blue icon, it will fix the printer.
