Marzipan
I tried making a bootable Chrome OS Flex USB key yesterday and what I got is so messed up I'm thoroughly confused.
you install the Chromebook Recovery Utility extension, connect your formatted USB key (8GB min and mine were 32GB and 64GB, Sandisk and Kingston) and choose it from the list of drives available, then specified the Chrome device you had or selected Chrome OS Flex as a general option and it does it's thing. then I get a popup saying 'format USB key' and then it cascades a dozen or so FIle Manager windows for that many partitions on the USB key.
checking the drive under My PC >> Manage shows a bunch of small partitions and a bunch of unpartioned space. It let me delete all but one partition marked EFI where it doesn't give me the option to delete it.
I Googled this and found instructions on using diskpart, which gives an 'no device' error when I select the offending volume and try to clean, etc.
now I have 3 USB keys (1x 32GB and 2x 64GB) that cascadethe dozen partition in File Manger windows with error messages and instructions to format or plug in a drive for the letter issued the partitions, which are not accessible in File Manager. I click cancel on all those pop ups and then the File Manager windows close.
what the heck has happened?
