mGz
New benchmark results of the upcoming Rocket Lake-S CPUs have emerged today on Geekbench.
The Core i9-11900K the flagship of the 11th Gen Core series that have not yet been officially released by Intel, has been spotted by @leakbench on Geekbench for the first time with a clock boost frequency over 5.28 GHz. This 8-core and 16-thread processor will be Intel’s next top SKU in the upcoming series.
Despite offering fewer cores and threads, the CPU is able to match the current-gen Core i9-10900K CPU in a multi-threaded benchmark, while offering much higher single-threaded performance. The 11900K has been tested on the Gigabyte Z490 AORUS Master motherboard which apparently already supports the new processor.
Meanwhile, China-based company Colorful, which recently announced its new Z590 motherboard series, appears to be evaluating the performance of another 11th Gen Core CPU, the i7-11700K, according to another leak from the Geekbench database. Interestingly both CPUs are to offer similar core and thread configurations but the i7 series is to be offered with a lower frequency.
The 11900K has been tested with a clock speed of 5.28 GHz, which might be the actual Thermal Velocity Boost for this SKU. The software does not confirm how many cores have reached such a frequency though. The 11700K, on the other hand, has only reached 4.58 GHz maximum frequency:
Intel Core i9-11900K and Core i7-11700K Specifications, Source: Geekbench
Intel Core i9-11900K and Core i7-11700K Scores, Source: Geekbench
The CPU has scored 1892 points in the single-core benchmark. Assuming that this is a stock configuration of the processor, then we have a new top score in the Geekbench V5 ranking. So far the highest score belonged to Ryzen 9 5950X, which reportedly scores 1682 points on average. Of course, the situation is completely different when multi-core performance is considered, then the Core i9 CPU is clearly at a disadvantage.
Intel 11th Gen Core ‘Rocket Lake-S’ Specifications
CPU Configuration Single-Core vs 11900K Multi-Core vs 11900K Geekbench V5 Performance Intel Core i9-11900K 8C/16T @ 5.3 GHz
1892
100%
10934
100%Intel Core i7-11700K 8C/16T @ 4.4 GHz
1551
82%
8849
81%Intel Core i9-10900K 10C/20T @ 5.3 GHz
1402
74%
10933
100%AMD Ryzen 9 5950X 16C/32T @ 4.9 GHz
1682
89%
16726
153%AMD Ryzen 7 5800X 8C/16T @ 4.7 GHz
1669
88%
10427
95%AMD Ryzen 9 5900X 12C/24T @ 4.8 GHz
1664
88%
14061
129%AMD Ryzen 5 5600X 6C/12T @ 4.6 GHz
1606
85%
8102
74%Intel Core i7-11370H 4C/8T @ 4.8 GHz
1556
82%
5177
47%
Source: i7-11700K via @TUM_APISAK, i7-11900K via @leakbench, Specs via @harukaze5719
Intel 11th Gen Core Comet Lake-S Intel 11th Gen Core Rocket Lake-S SKU Cores / Threads Base Clock Single-Core Boost All Core Boost TDP Rumored 11th Gen Core Series Specifications i9-11900K(F)
8C/16T
3.5 GHz
5.3 GHz (TVB)
4.8 GHz (TVB)
125Wi9-11900(F)
8C/16T
2.5 GHz
5.2 GHz (TVB)
4.7 GHz (TVB)
65Wi7-11700K(F)
8C/16T
3.6 GHz
5.0 GHz
4.6 GHz
125Wi7-11700(F)
8C/16T
2.5 GHz
4.9 GHz
4.4 GHz
65Wi5-11600K(F)
6C/12T
3.9 GHz
4.9 GHz
4.6 GHz
125Wi5-11600(F)
6C/12T
2.8 GHz
4.9 GHz
4.3 GHz
65Wi5-11500(F)
6C/12T
2.7 GHz
4.6 GHz
4.2 GHz
65Wi5-11400(F)
6C/12T
2.6 GHz
4.4 GHz
4.2 GHz
65Wi3-11305
4C/8T
3.8 GHzTBC TBC
65Wi3-11105
4C/8T
3.7 GHzTBC TBC
65Wi3-11100
4C/8T
3.7 GHzTBC TBC
65W
S - https://videocardz.com/newz/intel-core-i9-11900k-tested-in-geekbench-with-5-3ghz-clock-speed
Interesting. If these i9's are capable of hitting 5.3GHz on all cores then I'll be very tempted to upgrade. The IPC gain alone (coming from an 8th gen) will be worth it for gaming in order to increase fps lows. I've been hitching pretty bad in certain titles.
